BAproject
- Joined
- Sep 2, 2009
- 276
Hi All,
As I am still new at this whole boat repair and restoration I have made a few mistakes along the way.
When I pulled the intake manifold off to inspect, clean, etc...I did not mark the position of the distributor. Luckily the clamp that holds it down had left indents in the paint so I was able to line it back up properly upon installation.
Of course thats not my problem. With the distributor out I accidently turned the engine. Now I read in the manual you are not supposed to do this, but I read it after it happened. The good news was then engine turned fairly easily (no plugs in it right now) after sitting for 5 years, so I doused the cylinders with mystery oil and turned it around a few times to make sure it was nice and free.
Sorry for the long post! So the distributor is keyed and it seems that it can only go in in one position which I have successfully done, but I am wondering if I really screwed up the syncing on the distributor gear and will I be able to diagnose better with a timing light? Please help! I am afraid to even try and start the engine if the timing is screwed up. and as far as I know to properly time an engine it must be running.
-BAproject
-BAproject
