gene8084
- Joined
- Sep 29, 2007
- 187
Mercruiser, Ford 302, Motorcraft - Non vacuum advance distributor.
Idle timing set to 10 degrees BTDC per manual.
Any thoughts?
- When I set the timing, bolt down nut loose the engine sounds great (idle and throttle advanced).
- When I tighten the bolt down it sounds rough at idle. (I confirmed the timing is still dead on 10 Degrees BTDC.)
- When I advance the throttle (1900-2000 RPM) the engine vibrates. Timing appears to advance smoothly well past the timing marks.
- I set the point gap to .017 per manual (feeler gage). I will check the dwell with the meter, but didn't think this could be the cause.
- Confirmed wires are connected in the correct firing order.
Any thoughts?
