Timing
topdogeye
Can the timing be adjusted any other way than getting the motor up to 5000 rpm s? This is on a 89' 60 hrs evin. Also if my cavitation plate is below the botom of the hull would this lower the output of rpm s.
Randyg123
Re: Timing
I am not positive this applies to you engine. Someone should chime in and say so. Don't go by my opinion that it will apply.
Go up one notch in the forum Section to the Engine FAQs section and look for the post from Joe Reeves called "Joe Reeves WOT timing procedure"
This procedure may apply to your engine.
Good luck!
http://forums.iboats.com/showthread.php?t=228183
Benny1963
Re: Timing
that will work for you if your motor is equiped with slow features then they will need to be disabled ,also you may need to get you a manual
Benny1963
Re: Timing
yes if your cav plate is below it can lower rpm if you are running a motor setup for a different length transom putting yor plate 4 or five inches below the boat you will have seious probs ,
topdogeye
Re: Timing
Not that low it's only about an inch or so lower than the bottom of the hull. I don't know if I have the quick start setup I will try to look it up although it is an 89' VRO 60 hp. So if it is not the quick start than I would set the timing to 19 degees btdc ?
topdogeye
Re: Timing
I cleaned out the carbs yesterday engine starts rite up never better all I need to do is get the timing rite going to take it out later will get back if there are any problems.
5150abf
Re: Timing
Just used Reeves method, couldn't be easier, done in 10 minutes.
topdogeye
Re: Timing
ran boat today takes off like a champ timing was dead on. Thinking about changing the impeller any pointers of loosening the bolts on the lower unit as they are probably siezed?
5150abf
Re: Timing
If you run into problems with the lower start a new thread.
