timming gear cover rusted out
htoyota
I have a 1978 181 cid omc chev engine that requires a new or used timming gear cover,its rusted out in several places,does anyone know where I can get this item? I live in Nova Scotia Canada.
wire2
Re: timing gear cover rusted out
If you can establish what car model/years used that engine, might be able to order from NAPA or GM. Can ask both?
htoyota
Re: timming gear cover rusted out
I will check ebay,also the 181cid is a 3.0L chev engine I should have mentioned that.
htoyota
They tell me this engine was only used in marine applications
180shabah
That engine has only been used in industrial and marine aplications for the last 40+ years. NAPA should be able to help you, just get one for a mercruiser of the same year. You will also want to replace the oil pan, if it is not leaking now it will be soon.
happycamper
htoyota,
I have the same motor (although it's a '97). I have found that many parts are equivalent to the 4 cyl. used in the Chevy II, which was built in the 70's (I think).
Napa, Autozone, Checker and Pep Boys usually find what I want when I tell them to try that vehichle/engine.
A local boat dealer told me about this, and it has worked many times.
Good Luck
I forgot to mention that the motor in the Chevy II was a 2.5L, but several parts are compatible.
htoyota
Thanks guys,I will try Napa again using the chevy11 2.5 L engine,hope they can help.
whywhyzed
Banned
That will work, but the timing marks are in a different spot....p.m. me - I have covers I can send you one
htoyota
Thanks for the replies guys,KJDKJD has a cover so I will be running soon.
