timming issue merc 260/5.7
mlambert
having trouble with timming. time stays advanced cannot get below 10-12 degrees should be at 8 what is going on?what should i do
thanks
Re: timming issue merc 260/5.7
We gotta know What you've got for Power,......
Merc. has used the 350 Chevy for 30 years, with different Ignition systems.......
Is this Points,..??....
T-Bolt IV,..??...
T-Bolt V,..??....
Got a Year or Serial #,..??....
mlambert
T-Bolt IV,..??...
T-Bolt V,..??....
Are you setting the T-Bolt V into Base Timing Mode with the Jump Wire,......
If Not,.... The Spark Controller is Faster than You are at changing the Timing.......
mlambert
can you explain the proceduere what is the jump wire
Don S
Are you sure you have a Thunderbolt V, the 1990 model only had a TBolt IV system.
Don S
In case someone upgraded the engine or ignition system somewhere along the way. Here is the procedure used ONLY on the TBolt V, it's not used on the TB IV system.
mlambert
sorryy guys i checked last night i have t-bolt IV is it the same procedure as the V
thanks
Nope,.......
The T-Bolt IV Doesn't have a Base Timing Mode,.....
Just throw the Light on it,+ Set the Timing.........
Make SURE that you have the Idle set right,..... That'll Screw it All Up......
Don S
Reel Poor
Can you explain whats happening, ie, distributer won't rotate, engine dies, or other?
mlambert
timming will not get below 10-12 degrees. it will ping if i run up above 3200 rpm i dont really ever push it that hard but i know something is not right and that bothers me and the engine.
Haut Medoc
I think what Reel Poor is asking is when it will not go below the 10-12 degrees, it is because the distributer will not turn any further?
So I have to ask: Are you on the correct wire? #1?
& are you sure you have the correct position of the ign. wires?.........JK
