Re: Tin roofing as underskin?
I recently picked up an old pontoon for fishing. I was wondering about the underskin. I have read multiple posts on here regarding aluminum sheet as underskin material. Well, this old boat has tin roofing material used as the underskin. It may not be the prettiest but it seams to work fine and is not very heavy. Any major disadvantages of this? I just thought this might be a suggestion for the budget minded folks on here looking to add an underskin without dropping too much cash. Please blast away as I am interested in your comments!
Make certain what the old roofing is. check with a magnet and if it is old galvanized steel roofing you need to check for currosion, because steel and alum do not mix. The electrical charge between the two dissimilar metals will gradually eat our your cross members and the old roofing.
If it is galv Steel you need to seperate the materials by using 30# roll roofing material or something else (as sugggested by the members of the forum) to seperate the 2 metals.
Remove the old roofing, cut strips of felt the width of your cross members glue the strips to the cross members, with some cheap glue, and then reattach the old roofing using SS screws. oxbowaster
