OK, so I use the shop manual to pull the lower unit to replace the water pump impeller. Everything went well. Putting it back together, I've run into a problem: I can't get the shift linkage re-connected. The manual simply says to re-connect. Any helpful hints, or is is pretty much trial and error?- Hard to do as a one man job...Thanks in advance
