Manual for '98 Johnson 90 HP SPL says thermostat should be serviced when powerhead is removed. This makes me think I will have problems if I try to change thermostats without removing powerhead, which I do not want to do.
So what are the problems if powerhead is not removed? Does it have to be removed? Are there any tips and tricks to replacing thermostats without removing the powerhead. The reason for changing is: the discharge is always cool. The cylinders are always cool enough to leave your hand on them. So, I feel that the thermostats are stuck open for whatever reason.
Thank you.
Thank you.
