CreekCruiser
- Joined
- Jul 13, 2014
- 42
I am in the process of rebuilding my boat and I have a couple questions about the stringers in particular: a little backstory: I had a soft deck and took the advice of some forum members and cut it out to see what the damage was. The stringers in the front of the boat were pretty well trashed so I am cutting them out and replacing them. I currently have about a 1" lip around the perimeter of the deck and I am using this lip along with a straight edge and tape measure to try to duplicate my exiting stingers as they are much thinner in the front of the boat than in the back. Basically I marked the stringers every four inches and at that mark I lay the straight edge from "lip to lip" and then use my tape measure to measure down to the hull and record the measurement.
1: Does anyone know of an easier way to do this? The boat is almost 40 years old and the deck has warped in a couple places over the years. I plan on following the method in woodenglass' thread for stringer/deck replacement and eventually grind this lip off but I was hoping to use it as a constant to make my new stringers but it is far from constant.
2. The stringers slowly taper from 1 1/8" to 3". Any advice on how to lay this out on the new wood? What I have done so far is measure the existing stringer using the method described above and I have basically charted each stringer on 4" increments. For instance at 8" from the start of the stringer my height is 2", at 12" back it is 2 1/8" etc. is this a pretty sound way to do it? I figured I could use a jigsaw and get it pretty close and sand it smooth.
3. The measurements of the two stringers are not always an equal depth. For instance at 32" from the beginning of the stringers one side is 2 3/8" and the other side is 2 3/4". I know I mentioned that the remaining lip is kinda wavy and that might be the issue. What should I do in this situation? Should I cut each stringer exactly as I plot it or should I just average the two and cut them identically?
4: The boat is currently sitting on the trailer, I believe to be fairly well supported. Would it be better if I put the boat on the ground to minimize flexing or is this not an issue for a boat like mine?
Thanks for looking
Thanks for looking
