Fishermark
- Joined
- Oct 19, 2003
- 5,617
I bought a kit that has all the o-rings and seals to completely re-seal my outdrive. It is a 1990 SP-A. I already have the upper disassembled and am in the process of putting it back together with new bearings. That seems pretty straight forward.
I did not pressure test the drive before I disassembled it - but it looks like the lower seal around the prop shaft needs to be replaced. I have the two bolts out that holds the lower carrier in place. Any tips on pulling it off? The manual calls for a special tool - looks like a basic slide hammer. I read somewhere where someone had made a plate that you could use as a jack plate. Any ideas? I am afraid to use a slide hammer as it seems like it would strip out the threads.
