weekendfisher
- Joined
- Feb 26, 2010
- 79
Hi Guys,
Just after some advice/tips on starting outboards in different scenarios.
In my case i am referring to my 92' 55HP Johnson and my 92' 50HP Johnson when i start them from cold like just after putting them in the water they both start up first turn of the key and off i go, Now after anchoring and fishing for an hour or two i go to restart and they usually crank for a bit then on the second of 3rd time start up, is there a different procedure to starting a warmish engine up should i not prime the bulb more am i flooding them ?
I know that it i start them up again after about 5 mins after shutting down i just turn they key for a sec and they start up with not priming or squeezing of the bulb required.
Just after so advice on the right procedure here so i can be sure i'm not flooding the engines or anything else
Cheers
Cheers
