Tire pressure??
timm4433
Hello,
I have a 1999 bayliner capri, I believe it is 19ft. I was wonder what PSI is recommended.
Load star K550 ST205/75 D
timm4433
I see the max pressure on my sidewall is 150 PSI. That is the only pressure I see on the sidewall, wouldn't that be over inflated? I am assuming you are not referring the maximum psi? I looked around the trailer and found a data tag and it recommended 50 psi.
NYBo
That's the "Don't exceed this during mounting or the tire may explode" pressure. Look for the pressure in the load rating statement: something like "Maximum load xxxx pounds @ yy PSI".
smokeonthewater
50 psi SHOULD be correct IF the correct tire is on the trailer....
Look closer it SHOULD have another pressure on the sidewall... Most likely it will be like: "max load xxxx lbs at xx psi"
GA_Boater
The OP has never said what load range is marked on the tires, only the tire size. Actually, he never gave the diameter, either, so I'm using 15".
Which one is Load Range D? ST205/75 D15 or ST205 R15
From etrailer - two radial and 2 bias ply tires;
Taskmaster ST205/75R15 Radial Trailer Tire - Load Range C
Karrier ST205/75R15 Radial Trailer Tire - Load Range D
Loadstar ST205/75D15 Bias Trailer Tire - Load Range C
Loadstar ST205/75D15 Bias Trailer Tire - Load Range B
WIMUSKY
Check this out. Same for trailer tires. Except the size will start out with an ST rather than a P. And if the D is in that string(instead of R), it means it's a bias ply. If the D has Load Range preceding it, well, that's what load range it is...
http://www.discounttire.com/dtcs/infoSidewall.do
GA_Boater
Well I see someone edited a post to make the following posts look asinine.
TCATTC
Load Range B 35 psi (240 kPa)***
Load Range C 50 psi (350 kPa)***
Load Range D 65 psi (450 kPa)***
Load Range E 80 psi (550 kPa)***
Load Range F 95 psi (650 kPa)***
