Recoil Rob
- Joined
- Apr 23, 2010
- 16
I'm rebuilding the trailer that came with my GW 18' CC, it's an older SeaLion S-18-2450 single axle. Back then they built them with 4x3 frames, they currently built them with 3x3 frames.
They currently go up to 3600 on a 4x3 frame in that length and since replacement axles only come in 2200 or 3500 I thought I'll go up to a 3500# axle and springs.
My tires are currently Loadmaster 205/75 r14 with a load rating of 1760 @ 50psi. max. I notice that on most 3500# trailers use a 215/75R14 or a 205/75R15 with closer to a 2000# rating.
Total weight of boat, trailer, engine equipment and gas will be around #3200 (original trailer was apparently overloaded!), is it necessary to uprate the tires? If so better to go with wider 14's or 15's?
thanks,
Rob
thanks,
Rob
