Re: Tire size question
That depends on the load you are carrying. Check the sidewall of the tire for the maximum load the tire is capable of carrying and multiply by two if it's a single axle trailer. If the weight of the boat, motor, trailer, and all the gear, gas, adult beverages, etc is less than that number, its ok to use them. EXCEPT -- you should be using ST (special trailer designation) on a trailer. Yes -- people use regular car tires but at their maximum load they build up a great deal of head. Passenger car tires are rated at 35PSI. ST tires are rated at 50 PSI.
