Tire Wearing?
stratos21
I own a Stratos tandom axle boat trailer.The problem is my left side front tire has started wearing,while my other three tires are not wearing at all.Any suggestions? How and where do I get this problemed resolved? Thanks!
Stratos 21
Silvertip
Re: Tire Wearing?
What's the wear pattern? Outside of tread, inside of tread, center of tread, cupping, what? Could be anything from underinflation, overiinflation, out of balance, bent spindle, loose wheel bearing, loose "U"-bolt allowing axle to move out of alignment to name just a few things.
bruceb58
Re: Tire Wearing?
What is your history with this trailer?
Did you buy 4 new tires and this is all of a sudden happen or have you been running for awhile and this wear just started occuring?
stratos21
Re: Tire Wearing?
It is wearing on the outside.
stratos21
Re: Tire Wearing?
I have been running these tires since I bought the boat in 2001.
bruceb58
Re: Tire Wearing?
Did you verify any of the things like Silvertip said regarding bent spindle, axle out of alignment...
After you verify those things, it could be a falulty tire or you damaged it by hitting it. A belt that has slipped inside the tire can cause this to happen.
D
DJ
Guest
Re: Tire Wearing?
Something moved on the trailer. Bent, most likely.
If the axle moved, on the trailer, you'd see corresponding wear on the inside of the tire (opposite side), on the same axle.
My guess is that wheel took a curb shot and bent the spindle mount.
