Re: Tired of cheap Batteries
Yes I buy walmart batteries and the Marine batteries only come with one year warrenty. I'm lucky to get two years out of them. Yes I live in AZ and the Batteries sit in the heat most of their life either in the boat or in the Garage. Our summers are long
In the off season is there is really an off season in AZ I hook them up to a Smart charger once a while to top them off.
Should I be doing this with a Float Charger instead? Am I just wasting money if I buy expensive Battieries? Are the 5 yr warrenty pro rated or 100% replaced during the 5 years from Sears.
Thanks all for the replies
I'm of the opinion that you should only buy expensive batteries if your boat has a charging system that will support the correct charging cycles, (generalized terminology). If you don't, the finest battery you can buy won't last much longer.
There's several schools of thought about how to charge batteries in the off season but in reality there is only one proper way when dealing with standard lead acid batteries. That's the flood, charge, float method. Do battery tenders work? Well, sort of but you're actually better off letting them discharge to about 80% and then sending them through a normal charge cycle. The need to be dilligent about this is critical so most people opt for the tender because the end result is generally a fully charged battery but there will be some loss of life from overcharging as many have also found. You can read about that controversy in many threads here.
Here's the deal, a marine starting/deep cycle (combo) battery needs to be recharged when it reaches about 60%. A deepcycle lead/acid or AGM can go to 40% and a Gel can go to 20%. All batteries have a maximum number of charge cycles that they can withstand. For most lead acid it's 180-200. AGMS are about 120 and Gel's are closer to 100.
Think about it, if you only charge a battery when it truly needs it, you'll get far more use (life) from it then charging it all the time.
