rcl700
- Joined
- Jul 8, 2008
- 161
I have looked at the tohatsu web page and it recomends the following
Do I need a special battery to start a TLDI??
Because of the additional power requirements needed for a direct injection, TLDI? motors require you to use a marine battery with the following rating:
850 Cold Cranking Amps (CCA)
For users in colder climates, you should use a battery with a rating of:
1000 Cold Cranking Amps (CCA)
Why is it recomending a marine battery?
This is alot of cranking amps for a marine batt.
Would a cranking battery with high CC amps work?
