rcl700
- Joined
- Jul 8, 2008
- 161
Well I just finished rebuilding lower unit and placed the motor on the transom of my pontoon. Hooked everything up ( fuel,batt.,tac. )
new 12 gal fuel tank and new gas from the station that day. Battery fully charged new plugs (autolite)
Turned the key first time > fired up and ran for about 1 1/2 min.(with muffs on) Then cut off
after that it will not restart
I don't know what's up.
Can the fuel be bad? (it came from BP that day)
I was thinking it may have run on the fuel that was in the lines and pump ( old fuel that was treated with sea foam before motor was removed) then when it got to the new fuel it cut out. Does this sound likely/ or possable?
How can I clear the fuel system of existing gas and start with new fuel agin?
Do I need to put sea foam in all my gas?
How can I tell if all cylinders are firing?
What else should I look at?
thoughts please. Spring is just around the corner.
Thanks guys.
Thanks guys.
