Incaboater
- Joined
- Mar 12, 2007
- 33
When I 1st put the boat in for the day I squeeze the bulb until it is nice and firm, then I choke the engine with the key while starting in fast idle. The engine starts immediately and I let it warm up for a sec in fast idle. Well after going to my fishing spot and shutting off the engine for about 45 minutes its harder to get started then when I 1st put it in the water?? What do I need to do to get it to start after its been sitting in the water while using the trolling motor. Should I choke it again and have it in fast idle just like I did originally or should I just turn the key?
Also my boat idles perfect, though it dies in really slow forward or rear throttle, like the speed ( walking speed) you need to get your boat on the trailer. Whats causing that?
The motor is a Johnson 1981 70 hp seahorse.
Thanks again for all your help guys, you helped me out a great deal!!
