Re: to choke or not to choke....
Spur <br />All righty then! Great, you got the book, ya got the parts and ya got this board. Should be a cake walk. I personaly don't like soaking a whole carb body. I doubt it would be necessary any way. Just remove the needle valves, the bowl,filter, float, and float valve. Wear eye protection! Squirt a little carb cleaner through all the holes, blow them out with air. Then put the hole mess back together useing your new parts, adjust yer needle valves and go kill hogs.
