Re: to foam or not to
I did add foam to my boat during the rebuild, but I did NOT use pour in place foam. I just am not convinced the stuff will not soak up water.
Being involved with construction, I used something I am familiar with . Owens Corning, or Dow makes it as well, Foamular building insulation panels. We use these suckers BELOW ground in construction and I have not seem them soak up water. I bought the 2 inch thick sheets at the Home Improvement store and cut them to fit..
http://www.shareaproject.com/pages/imageDetail,p,148,i,2768,00.html
This stuff is also cheaper than pour in place foam, yes its more work, thus the term sweat equity.. The 2 inch 4 ft x 8ft sheets are 5 1/2 cu ft per sheet. Given that water weights 62 lbs per cubic foot, and we'll discount the 2 lbs, call that the weight of the foam, so 60 lbs / cu ft times 5 cu ft = 300 lbs of flotation per sheet.
