Advanced Anglers? newest generation of ProSeries On-Board Marine Battery Chargers boast updated, all-digital microprocessor-controlled charging technology and are now up to 40% lighter. Bank trouble status LEDs show you exactly when your battery or its connections require your attention, while the all-new battery recondition mode keeps your battery?s performance in check every 21 days. Rugged 100% waterproof, shockproof design delivers advanced electronic technology in a heavy-duty, compact and lightweight case. Designed by ProMariner, sequential multistage charging gives you the peace of mind that your batteries are being charged, conditioned and maintained, so they are ready when you are. Each charger offers two precision charge profiles that are easily selectable: factory set or out of the box. ProSeries delivers a Performance/Flooded (Lead-Acid)/AGM Battery-Charge profile that will be friendly to your batteries while extending their life and delivering a full charge every time. ProSeries Maintenance Mode is completely safe for short- or long-term storage. ProSeries Distributed-On-Demand? charging technology, which takes 100% of the available charging amps and distributes them to any one battery or combination of all batteries as needed, is combined with its extruded-aluminum housing for increased power and faster charging. ProSeries enhanced feature set includes: a digital battery-charge profile selector that allows you to select the charge profile to match your battery type to include flooded (lead acid)/AGM or gel batteries, expanded LED status center identifies AC power, charge mode, ready/maintenance mode, reconditions mode and battery type. All multibank models include dual-in-line DC cable fuses for maximum battery cable protection and safety. Performance built with maximum protection including: ignition, polarity, over voltage, over temperature and short-circuit protection. All models include thermal output control ? providing the appropriate charging amps to your batteries, while maintaining the recommended temperature of the Advanced Angler ProSeries charger. Constructed to Marine UL and FCC Class Guidelines. Pre-wired for easy installation.
