Hello everyone, (first time poster)
Ive got a blown piston on my '95 johnson 112 spl outboard motor.
Motor has about 100 hrs all in saltwater. I took fairly good care or motor, flushed after every use, changed lower gear oil/spark plugs bi-annually. alway used fuel stabilizer for winter storage in the 50-1 mix. Motor was very dependable til last week, when it started running shaky. I thought it was just bad fuel or bad plug so I limped it back to marina and took it home.
I pulled plugs and saw smashed electrode and met bits in one cylinder, which prompted me to do a compr test, that one was bad, 10-15 lbs, all others 110-120. So I pulled the head and saw a hole in piston top exposing the ring. Suprisingly, no visual damage to cyl and other hole is perfect. both cylinders look very good with no scores and only visible cross hatch.
Im gonna try and post pictures, what concerns me is the pitting in the top of the head, and the head gasket was good.
Im a decent garage mechanic, with alot of american v-8 exp, but no outboard exp.
