to seal or not to seal????????
cp1109
Hello I had a quick question I rebuilt my gear case on my 18hp Johnson and when putting the impeller housing back on I put a vary small amount of sealent on it and assembled it. Does it need it or will it hurt it? So as it stand it goes housing impeller and the plate the housing was sealed to the plate and the impeller moves just fine inside it. I haven't started it yet o wanted to ask before I did thanks a lot guys.
Joe Reeves
Re: to seal or not to seal????????
You did right....... sealer should be used between the plate and lower unit and also between the impeller housing and the plate.
cp1109
Awesome thanks for letting me know the book said just lock tight on the screws. Well now I can fire it up with no worries.
