Re: To trim or not to trim?
When teaching my friends and wifey how to drive my boat, I always say "speed up trim up, slow down trim down". And always all the way down for a hole shot. One other note, I have a 190 hp I/O with a deep v-hull. At slow speeds it tends to wander back and forth. I have found that this can be somewhat improved by trimming up some instead of completely down.
I totally agree with the non-use of a trim gauge. My sender broke after just a few years. You really need to learn the feel of being properly trimmed vs. using a gauge. Your trim needs are also effected by how you boat is loaded. More people aft will need more trim.
As someone else mentioned, trim is meant for a smoother ride and a more econimic ride. With trim positioned all the way down, as you increase speed the nose of the boat is driven into the water, causing more resistance, rougher ride and more water splashing into boat and passengers.
Bottom line, if you have an accessory like trim, learn to use it and appreciate it.
Fishing56
