ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 933
Trying to get my old 15hp to run well. it lean pops at idle, like it's out of time, but it isn't. compression is high and even, new suppressor plugs (ngk b7hs-10's) rebuilt carb and set timing. Im an OMC guy, and noticed the plugs fire at the exact same time! Thinking Power pack, but I lost my old service manual and can't find another. the specs for the newer ignition components I have (c and D models). So far I have found this: Primary ignition coil is .6-.8 ohms... supposed to be .2-.3. secondary I get no reading on either plug boot. Is that normal? if i had the correct manual, i could do all the DVA tests and know proper specs, or are they all the same?. Any help would be awesome!
