tohatsu 1986 9.9
memory
this unit belongs to a friend and has no spark, I would like some info on how to check the magnito, and the cd unit, and the rectfier, I have meters and have knowledge of how to check things but I need values on these pieces. thank you for your help.
pvanv
Re: tohatsu 1986 9.9
We need your full model, for example M9.9B2. Be advised that most ignition and carb parts for the A and B models are NLA.
memory
the full info on this unit is as follows M9.9B2 355A 60331 1986 I hope this will help. thank you.
pvanv
Few parts remain for those early models (no carb kits, etc.), unless as NOS on some old-time dealer's shelf.
362060220M TRIGGER COIL-NO LONGER AVAILABLE
350060210M EXCITER COIL-NO LONGER AVAILABLE
However, the CD module (362060601 is superceded to 362060602M) is still available:
362060602M C.D. IGNITION UNIT (CU15 KOKUSAN DENKI) $179.60
And the ignition coil (362060500 is superceded to 3M3060481M) is also available:
3M3060481M IGNITION COIL W/RESISTANCE $43.73
If you need parts for the charging circuit, which is independent of the ignition system, the alternator and rectifier are as follows:
350060230M LIGHTING COIL $48.27
(346761601 is superceded to 346761602M)
346761602M RECTIFIER KIT 8B THRU 40C $99.78
To diagnose the ignition system, you will need to verify whether you have shorted or open trigger or exciter coils. If bad, you are done, as no replacements for those are available. If OK, then check the CD and coil resistance values. If you get an ambiguous reading at the cd or coil, connect a DVA to the primary side of the coil and see if you are getting at least a 50-100v pulse from the CD. If yes, problem is at the coil; if no, the problem is before the coil.
Grab your good Analog ohmmeter (not a digital unit), (you should have DVA capability on the meter to read the pulse from the CD to the coil), and a copy of the Factory service manual, 003-21035-1 $42.47. Once you diagnose it, and possibly get it running, you will likely also want a water pump kit: 362873220M $46.42.
HTH
memory
Thank you paul for your responce, I took a look today and I have nothing from the rectifier going to the mag. I should get some sort of voltage should I not? I have a good 12.65 in. I am thinking this acts as a balist resister yes?
pvanv
No. Works the other way around. The flying mag will make AC 9when the motor is running), which is rectified into DC by the rectifier for battery charging.
