Tohatsu 2001 MD50A TLDI
rich10975
Hi there i have a Tohatsu 2001 MD50A TLDI,I am in the process of changing it from tiller steer to remote control,I have already bought my new (RC5F) CONTROL BOX,Draglink "E"assy,Steering hook plate,tacho meter,trim meter and i am yet to mount it all still waiting on some parts to arrive,But my question is as for throttle and shift linkages can i use the same ones and what do i need to buy to hook all my cables to my motor and secure them,tohatsu told my they dont do a R.C fitting kit for this motor.could someone please tell me what i need and part numbers so i can buy the linkage parts or clips or cable ends i need to finish this.my dealer where i live just wants to rip me off and sell me everything and even tryed to tell me i cant get the parts and wanted to sell me a new motor:facepalm:,mine only has 136hrs on it.:) On the bottom of my throttle linkage is a little tapered peg sticking out with a tiny hole in it that looks like a clip or pin would go through it,but as for shift i gotta take off the out side shift paddel and what bracket do i need to hook cable to it and motor has 2 treaded studs in it on linkage side i assume there is a rubber and a bracket that goes here to succure cables i need part numbers or names of parts please if anyone can help me.
pvanv
Re: Tohatsu 2001 MD50A TLDI
Do you have the Factory service manual and parts catalog? If not, you need to start there. This conversion is complex, with a lot of small parts. This job would normally be done by a dealer. No, there isn't an SRC kit for the conversion. You use the same shift assembly; the internal shift rod gets replaced with the cable, and you remove the cowl-mounted shifter. Likewise, the throttle setup uses the same advancer arm. Any dealer can help you. If you'd like, you can drop me an email at the office: paul@obersheimersails.com
rich10975
hi paul i got a factory parts catalog i bought it on ebay just waiting for it to arrive cant get a factory manual so i bought a seloc manual and hope that can guide me abit,but if it cant i will have to download the factory repair manual.
pvanv
The Factory service manual is copyrighted, so it is not available for free download. The seloc manual is a start, but is very general, and covers a lot of motors -- not just yours. I highly recommend you get a Factory service manual, Part # 003-21050-1, $27.58, from any dealer, including me. I'll be in the office tomorrow (Wednesday) and can help you then. If you need anything, call 716-877-8221, 9-5 Eastern.
