Anyone know what it sounds like when the rev limiter kicks in on a motot when it engages? I have a 2010 Tohatsu 20 hp 4str that after 6 months started making a sound at the very top end of rpms. I have switched to stainless steel props since then and now it does it even more. Lately its getting to the point where I'm having to adjust the throttle linkage so that the carb does not open all the way when the boat is under a light load. But when the boat is under a heavy load it does not do it at all. I can run it all day just under WOT and no problems but then as soon as you pass a VERY specific throttle position it immediately starts making the sound and tops accelerating. Sounds like the motor misses. I'm a little confused and sick of having to mess with the throttle linkage to get it not to do it. Would it be a timming issue if it only does it at peak rpms? The motor runs very well from idle all the way up to plane
