tohatsu 30 four stroke idle speed
pogyman
I have a brand new 30 and the factory set idle is 1800 rpm. It should be 850rpm. This is an efi model. I plan to get the service manual but haven't yet.
The throttle cable is not causing this, I disconnected it and no change. Is idle adjustment a simple matter?
TOHATSU GURU
Re: tohatsu 30 four stroke idle speed
Since it is "brand new" you need to take it into a Nissan or Tohatsu dealer for warranty service. They will then determine if the problem is the tachometer, the settings on the engine or the ECM.
pvanv
TG is right. There is a strong possibility that your tach is setup wrong, reading double the actual RPMs.
pogyman
Thanks for your responses. I checked the tach that was supplied with the engine with one of those inductive tachs that a friend lent me. They read the same. I also have access to one of those laser/optical tachs and I will check it with that tomorow. Either way I'll be talking to my dealer. I'm just trying to gather as much useful information as I can first.
pvanv
The correct tach pole setting for these motors is "12-pole". Keep in mind that while this is a 4-stroke... it fires on every upstroke of the piston (similar to a 2-stroke). That is... it fires on exhaust as well as compression. One spark per revolution... Not one spark per 2 revolutions, as a 4-stroke car would.
pogyman
Problem solved. The tach was on the 6 pole setting. Now I need to play with prop pitch. WOT is 5300 rpm with a 10X13 so I'm thinking a 10X11 to bring rpm up 600 to 800 rpm or maybe a 10X10? WOT on this engine is supposed to be 6250 rpm. This boat was originally set up with a Johnson 35 , 1978 spinning a 10.5 X11. It's a Simmon's Sea Skiff that I built in 1994.
