Tohatsu 30 four stroke leaking oil
Krazycajun
There are two holes even with the lower unit fill screw on the front of the motor. Came out the water yesterday an there was
oil coming out smell like lower unit oil.Tohatsu 30 four stroke.Where is coming from
pvanv
Re: Tohatsu 30 four stroke leaking oil
What is your exact model and serial? There is a tech bulletin for some 30 hp motors.
Those are drains that allow water out of the housing when the motor is out of the water, so it doesn't stagnate, corrode, or freeze. Check your LU lube level and condition. If milky, there is a seal, gasket, or o-ring leak. Also check the crankcase dipstick. The oil can't be overfilled.
