red october
- Joined
- Nov 23, 2010
- 7
Hi all, I'm new to boats and newish to 2 stokes, fair experience on 4 stroke and diesel.
My 2 questions are;
1. Does anyone know what year it is? Model # 365 01100 1 Crank side? 345 01100 carb side?
2. Recently i had the boat out for a run, I got about 2 hours running time, alls well. Got home started flushing with fresh water. Ran for about 2 min, then just stopped, no cough's or missing. I tried to start but no luck, pulled plugs and found wet with fuel, disconnected fuel, left plugs out, kicked motor to remove excess. Re connected everything, but still no luck.
I left it over night with the plugs out, found a puddle of black oil/fuel under prop / outboard, when I pulled the inspection plate off the air filter i found an inch of fuel sitting in the bottom of filter case.
After draining fuel system and filter case I left it over night again. Then tried it again with no fuel supply, Nothing. Tried spraying fuel through carb then through spark hole, Nothing. Checked spark and am gettin good spark on #1 but intermitten on #2? Plugs are dry now too.
Has the flodding brocken something? or is the spark an issue? On a car engine fuel + spark = vroom, if only briefly, but this has me stumpped.
Thanks for the help iin advance.
My 2 questions are;
