tohatsu 40 TLDI
jthawg
my motor has been sitting up for 4 months. I went to use it, it cranks but only runs off starting fluid. I checked fuel pressure with a gauge with the key on it reads 0 if i crank motor it eventually gets to about 60 psi. I checked the fuel pump to see if it is getting fire to the wires both blue and yellow wires are hot. Someone please give me some suggestions of what i might be overlooking :confused:
pvanv
Re: tohatsu 40 TLDI
What is your precise model? MD40A or B or B2? You may be within the 4-yr (3+1) warranty. Fuel pressure is low. What is the air pressure? Once you grab a copy of the service manual and follow through the fuel and air rail system, you will know more.
TOHATSU GURU
Re: tohatsu 40 TLDI
If you have a 40 TLDI you put the engine into its self diagnostic mode and let it tell you what is wrong.
