Tohatsu 6hp NFS-6 Impeller Change problem
jeffdawgfan
I purchased a impeller rebuild/change kit for above motor. I went to drop lower housing (only two bolts). The housing dropped about 1 1/2 inches and seems to be stuck. I see three rods coming down housing (drive shift, drive shaft, and another rod). How do I drop the houseing rest of the way down to removed lower housing to get at water pump???
Any help appreciated.
TOHATSU GURU
Re: Tohatsu 6hp NFS-6 Impeller Change problem
Remove the grommet on the leg to access the shift coupler. You really need a service manual before you start to do your own service.
jeffdawgfan
I have ordered one. Was trying to do this "simple" job without it. Was not as simple as seemed . :)
pvanv
... and that is why marine mechanics charge $75-100 per hour ;-)
