boatwiser
- Joined
- Aug 24, 2010
- 7
Hope someone can help me on this - I must be missing something.
My old faithful 8hp Tohatsu that has never given me a problem in over 20 years started running poorly for my son last time out and finally wouldn't keep running. I pulled the carb off and took it all the way down and cleaned all jets and passageways with carb clean and compressed air. Drained and flushed the gas tank and hose and filled with fresh gas. Changed out the engine gas filter. Checked compression - both cylinders around 115lbs. Checked spark and changed out the plugs.
Fired it back up and engine idles very low and dies out. If I keep it running by using the choke I can get my inflatable up on plane but cannot get full power out of it. Pulled the plugs and found one to be blackish and the other to be like it was never used.
Took the carb apart a second and third time with same results.
Could I have reversed the low and high speed jets or is that not possible? I checked out a diagram of the carb online and I believe it shows the rubber cap over the low speed jet. I think I have the rubber cap over the high speed jet - the jet that has the nozzle attached.
Any ideas??
Any ideas??
