Tohatsu 9.8 Carb flooding and leak
donnyk
I have a 2008 Tohatsu 9.8 four stroke just purchased form someone. It has sat for over a year. The carb had been rebuilt before sitting. When I pull the choke to start for the first time it floods the carb right away. I can see fuel dripping off the carb. When finally started, it will run fine, but if I shut it off and leave it sit for more than a few minutes it will flood again and is very hard to start. If I disconnect the fuel hose when I shut it off, it will start easier. Any suggestions? Even if the carb if full, should it leak?
Thanks for any help.
pvanv
Re: Tohatsu 9.8 Carb flooding and leak
Sounds like the needle isn't seating correctly, and you are overflowing through the vent. Remove the carb, disassemble it, clean the needle/seat, and verify the float height. I'm guessing you have an MFS9.8A3 model (year is unimportant)...
"had the carb rebuilt" could mean a lot of things. And, if the motor was mothballed with gas in the carb, the service was for naught.
TOHATSU GURU
Paul,
You know I was a double naught spy back in the sixties.:)
pvanv
Paul,
Elvin,
Didn't you mean "double-aught" ? :)
But, with Don Adams as Maxwell Smart (agent 86) and Barbara Feldon (as agent 99), there weren't many "double-aught" agents in the '60's :)
xjma
sounds like it could be a sticky float needle, was it stored with un-stabilized fuel in the carb? You may need to remove the needle and seat and soak them in gas for a while in order to get ethanol junk off of them.
