a while ago the engine would not start, there was no spark, after a little testing the coil was replaced and the engine started. again after a period of time the engine would not start, there was no spark. the kill button was replaced, no change, another coil was used, no change. using the clymer repair manual i performed ohm tests, the only thing that does not appear to check out is the c.d.i. unit, they are quite expensive, is there a way of testing the unit off the motor to be sure?
