Re: Tohatsu 9.9hp to 15 hp?????
Elvin!!!! Or should I say TG? It's me, Conrad (you know the guy who visits every week and buys parts I don't need for too much)
Hey btw - rockford is my brother. We got the motor humming nicely (thanks for the parts). It's even clean and pretty looking.
I took it out today and gave it a spin. It worked great with one exception - as the throttle is advanced, just before it reaches WOT, the motor starts to loose power, the RPM's drop and the engine starts to sound like it's struggling.
Wide open the speed and rpms are lower than when the throttle is about 75% open.
We were using a GPS and just short of WOT we were doing about 18-19mph and then as the throttle is advanced the rpms would drop and we slow down to 14-15 mph. I took the cowling off and observed that the butterfly was not fully open at 18-19 mph and then as the cam advanced further (opening the butterfly further) the rpms dropped as did the speed.
Is this a timing issue? Perhaps the carb is delivering too much fuel? I'm at a loss here.
IF the 9.9C gets the cam upgrade, does the CD unit need changing? Is it firing fast enough?
While underway I tightened the screw on the top of the carb(I believe it controls the idle) as much as I could without stalling the engine - and no luck there.
Any ideas?
-Conrad
