Tohatsu DVA Output,-
Sea Rider
Tohatsu specifies MIN 100 DVA outputs for most of their Exciter Coil components when cranking, which is the MAX it should go ? Data Remains unspecified.
Happy Boating
pvanv
depends on rpm. 100 is enough to charge the CD so why question the max?
Sea Rider
Have finished assembling my DIY AC/DVA converter, will check how it reads while cranking electrical components.
Just wanted to know to set correctly the multimeter scale using say 200 and not 400/500 Volt scale and not blow the meter during test. If you check the 3-4 cylinder OB's Service Manuals tech specs will see the min-max DVA posted range for Exciter Coil.
Happy Boating
