Tohatsu engine oil drain screw washer
Geezer1
I have a Tohatsu 4 stroke (2019 MFS 30C). It's time for the 20 hour service. I have the seals for the lower unit oil drain screws, but I'm having a hard time finding a part number for the engine oil drain screw washer. I believe it's made of soft aluminum (crush washer, not to be reused). Any help will be appreciated. Hope all are healthy out there during these crazy times.
pvanv
I reuse the crankcase drain washer (
3R3074060M
) all the time.
Geezer1
Thanks Paul. I was hoping to reuse it, doesn't look like its in bad shape at all.
Geezer1
Have you ever seen a dealership, when servicing a new engine, place a stainless steel washer of smaller OD between this crankcase washer and the drain screw? BTW, the old washer on it's own, did a fine job of sealing after I changed the oil.
