Tohatsu Failure to disconnect electrical problem man overboard
xenophora
Greetings, I would appreciate some information, I have a tohatsu 9.9 when start I can not stop, I tried to gather the cableslanyard stop switch, but remains the same, I can only cut gasoline supplies, would appreciate any help
Grub54891
Re: Tohatsu Failure to disconnect electrical problem man overboard
Did you actually remove the lanyard clip? It should have stopped the motor. If not I'd say the switch is defective.
Post a pic of the switch.
Grub
pvanv
Either the stop switch, the wiring, or the CD is bad. Most common is the switch. Next wire. Rarely, Rarely the CD.
