Re: Tohatsu M15B no spark
Be advised that you have a 3-decade-old museum piece, so beware the money pit. No carb stuff is available any longer, for example. But... if you do want to try, start with the Factory service manual, Part# 003-21035-1, $45.00, available from any dealer, including me. Diagnose the issue by referring to the table of resistance values. use a good analog ohm meter. Test the exciter (NLA), trigger (NLA), CD (over $212.00), and ignition coil (about $50.00). Some bits may interchange from a 25-year-old 15B2, but beyond that, you will be adapting stuff from a newer motor if it will fit. YMMV.
