Would anyone know if it is possible to increase the amp output of a alternator from a tohatsu 30HP (M30H)?
Also I need to instal a rectifier to charge my battery. Although I'm aware that the standard rectifier only puts out 5 to 6 amps. I would like to charge out more amps and would like to have a regulator to control the charge.
I was wondering if I could use the "regulator/rectifier 3AC-76067-0" which is off the 30hp four stroke (MFS30), I believe this regulator/rectifier can handle a much larger charge, at 15amps.
Could I instal the"regulator/rectifier 3AC-76067-0" which is off the 30hp four stroke (MFS30) on my 30hp tohatsu tow stroke (M30H)?
I know this may void the warranty, but with the warranty issues aside, the wiring input and out put seam the same.
