My M40C has been acting up for the last couple of outings. Here's a summary of what happens.
Motor starts and runs fine when cold.
When the motor is hot/warm, it won't fire.
Open the choke, motor fires and then dies.
Close the choke, motor fires and then runs roughly.
If you put the motor in gear at idle the engine bogs down and stalls.
If you put the motor in gear with some revs, it runs fine but stalls when it goes back to idle.
At the same time, I've noticed a lot of soot deposited around the exhaust.
At first I thought this might have been related to a loose plug. However, the issue is getting worse despite a new set of plugs, which I correctly torqued. I'm now thinking it's a carb issue and I have a carb rebuild kit on the way.
Are these symptoms consistent with a dirty carb?
Thanks in advance!
Thanks in advance!
