tohatsu m40c starter problem
chaseasl
My starter went out and I just received my new one yesterday, the only problem is I poped the old one off and can't get the new one on and I can't get the old one back on either, is there a trick to getting them to fit into place?
TOHATSU GURU
Re: tohatsu m40c starter problem
No, It bolts right up...Did you get an aftermarket starter or a new one from a Nissan or Tohatsu dealer?
chaseasl
aftermarket, but to be honest, I couldn't even get the original to go back on it
pvanv
Was there some interference or something?
chaseasl
Don't know but the new one I got was too long, hooked the old one back up and now somehow it is working, I'm confused but happy for right now, sent the new one back for a refund
pvanv
How (what method did you use) did you diagnose the electric starter was bad in the first place?
chaseasl
jumper cables, grounding the negative and hooking the positive to the starter
pvanv
So maybe you had a stuck or worn brush. If they are worn very short, you can get new brushes.
