Tohatsu M8B
Don321
I need help, I am trying to replace the water pump (impeller) but got stuck trying to take appart the lower unit, I disconnected the shift shaft and removed the 4 screws holdind the lower unit but so far the lower unit came appart about one centimeter and can not pull it out complete, any advise?
Don321
pvanv
Re: Tohatsu M8B
Patience, time and wedges should help you pull it out. Odds are the driveshaft is stuck in the crank splines.
