Tohatsu MFS20E tach/hour meter
Clarke937
I am new to this site and am looking for a combination tach & hour meter to install on the dash of my RIB. I don’t want a plastic stick on, that wraps around the spark plug wire from Ebay, but am looking for a proper dash mount mechanical/analog type.
Does Tohatsu make one for the 20 hp? Has anyone installed one that might assist with hookup in the motor?
I was hoping for an OEM that might plug into an existing pigtail. Does that exist?
pvanv
You will need separate tachometer and hour meter, The TOCS multifunction meter won't work on a 20E
Clarke937
Thanks for the info. Are there pigtails to connect separate tach & hour meters? Where would I find a diagram with info for the connections?
pvanv
If you have a Remote motor, use the tach lead wire kit 3R0725371M. Plugs right in.
Then select either a white or black 85mm tach, $125.00...
Then a 2" hour meter for $65.00
Hour meters are basically 12v electric clocks that start at Zero and count up whenever powered ON. If Remote, you can use the red wire from the RC box.
GA_Boater
Wouldn't a Tohatsu BFT model tach with built in hourmeter work?
pvanv
The $640 TOCS tachometer will work on the BFT models, but not on an MFS20.
Clarke937
For other owners who are interested in the tach/hr meter question the Tohatsu office in Texas answered my inquiry with the following:
“There are several aftermarket combo tach/hour meter gauges that will work. The pole setting for the MFS20 is 12 pole so you just need to make sure the tach has that pole setting to be able to properly read. Below is the wiring diagram for the 20EEPT model for connecting gauges. You will find an empty 4 pin connector that is where the gauge harness will plug into the control box or if you have a flush mount control the plug will be with the wiring under or in the console.
28ae43a7-f6e9-4ea1-8c6f-18630f8885a8
990a5812-5b4d-4d9c-bf1a-fb1c049469ba
pvanv
Your mileage may vary. Aftermerket tachs sometimes work OK, others not.
