Tohatsu MFS6B - Running the carb dry at the end of the day
rsnyder518
I've been doing as I've been told and running my carb dry at the end of the day, every day. My question is this: What's the right procedure? Do I just let it run until it stalls? I've actually played with the choke a bit as it gets close to stalling. I can keep it going a little longer and I figure that gets rid of even more gas. Is this good, bad or indifferent?
Also, I know that running it dry leaves a small amount of gas behind that generally doesn't cause problems. However, if I know that I'm going to be leaving the boat for a bit longer than normal at what point does it make sense to pull the cowl and drain the remaining gas out of the bowl? 1 week, 2 weeks, a month?
Thanks.
pvanv
Running untiul dry is typically OK; fiddling with the choke will draw some more, which is even better. If a month or more, such as for off-season storage it's best to drain.
