Re: tohatsu question
step one... get a manul, ebay has them, iboats has them, your tohatsu dealer has them<br /><br />step 2, remove the lower unit, usually about 4 or 6 10 millimeter bolts.<br />remove shift linkage<br />slowly slide lower unit down untill all is clear... dont drop it....<br />water pump is directly on top of lower unit, youll see it when it comes off. when you take off the housing cover, keep all the bolts, and if you have a digi camera or a camcorder, take pics or video along the way so you know how it goes back together<br /><br />when you remove impeller, be very slow. DO NOT LOSE THE IMPELLAR KEY ! KEEP IT SAFE !<br /><br />replace any applicable gaskets and drain and change your lower unit oil while your at it.<br /><br />once you do it 1 time, youll see just how easy and straight forward it is........<br /><br />and oh , the impellar will starighten itself when you put it on... do not worry, and yes, it IS SUPPOSED to be that hard to get the new one back in the housing<br /><br />m ikey
