Hi,
I have a 2008 Tohatsu 90 TLDI that has developed quite a bit of surface pitting/corrosion on the leg making the paint job look ugly. I would like to sort that out and then give the leg a re-spray so I was wondering if anyone could recommend a PPG color code number or do I stick with the cans from the dealer?
Should I be using an epoxy primer as sealer first and then using a PPG acrylic urethane top coat with hardner? Not sure if one then sprays a clear laquer on top?
I used the boat for 3 summer seasons leaving it saltwater (didn't put anti fouling on the leg), I cleaned the leg each time I went out and always changed the anodes when needed. At the end of each season the motor would be rinsed down so I'm quite surprised at the state of the factory pain/corrosion.
